Need help on pcv/ccv problem on 95 z28
Old May 31, 2016 | 11:54 PM
detroit_903's Avatar
Default Need help on pcv/ccv problem on 95 z28
Hello I have 95 z28 highly modified 383 supercharged lt1.. I'm having a serious issue with blow-by. When I bought the car only one side valve cover has a breather filter on it.. the push in type.. that's it I have no other lines or hoses going to the valve cover.. can anyone tell me how I can vent the system better..
Old Jun 1, 2016 | 04:31 AM
hrcslam's Avatar
You should also have a PCV on the drivers side of the intake manifold. It runs to under the TB on the intake manifold through a rubber hose.
You may want to look into either a Vacuum pump or a header EVAC system.
Old Jun 2, 2016 | 07:20 PM
The car is supercharged 11 psi. Just want to know if I can just run a breather on each side of the valve cover if that would be good enough.. or if I need a oil catch can. Do I just run one side to each can?
Old Jun 3, 2016 | 11:17 AM
Shownomercy's Avatar
Man-Crush Warning
Buy a Mightymouse can, run a line from each VC to the dirty side, and run a suck line to pre supercharger.
Old Jun 3, 2016 | 06:34 PM
ringmaster72's Avatar
Exactly what shownomercy said. You can install two fittings in the intake hat on the suction side of the blower. then run a line from each valve cover to these lines and I would recommend a catch can in line of the two lines. I have 2 catch cans, one for each valve cover line. I also still have my pcv valve hooked up, it also runs to the suction side of the blower.
