Coolant Type Change
Old Jun 3, 2016 | 04:52 PM
Casey Hungler's Avatar
Default Coolant Type Change
I just replaced the water pump on my brother's 97 Trans Am. The coolant that came out of the engine was definitely green, but when I went to the store to get new stuff, they told me I should be using orange. It looks like the car came with orange, but someone must have switched it over. I've drained/filled with water/ran the engine 4 times now, but I'm still seeing a little green in the radiator. Since I don't have access to a power flush system, I'm never really going to be able to get all of the old stuff out. Should I be sticking with green, or should I use orange?
Old Jun 3, 2016 | 05:49 PM
TrybalRage's Avatar
Yes, originally these cars came with orange dexcool, but if someone switched years ago to green I'd stick with that. You could also get the universal stuff if you are torn about it.
Old Jun 4, 2016 | 11:08 AM
BALLSS's Avatar
you really need to pull the knock sensors to do a complete flush if changing from green to orange
Orange lasts longer than green but I have been running green for 18 years now. I just use generic brand green usually sold under store brand name.
Old Jun 4, 2016 | 11:52 AM
Cajun ELESS-ONE's Avatar
stick with the green. the dexcool can corrode the gaskets over time. also green coolant and dexcool dont mix.
Old Jun 4, 2016 | 01:56 PM
Thanks for the input. Decided to stick with green. Now to give it some time and hope for no leaks.
