What wire for speedometer
Old Jul 4, 2016 | 08:32 AM
Viper's Avatar
Default What wire for speedometer
I'm trying to tap into the speedometer wire for hooking up a dash computer that displays it digitally. I know on the LT1 passenger kick panel, the blue connector has a white wire for the tach. I 'think' the green/white wire in the same connector is for speedometer, based on this from shbox: http://shbox.com/1/95_ta_cluster_pinout.jpg
Can anyone confirm?
I know the white wire is for tach (I hooked up a Harlan shift light) based on this: http://shbox.com/1/keyless_entry.jpg
Old Jul 4, 2016 | 02:54 PM
shbox's Avatar
C220 G should be it.
Old Jul 4, 2016 | 10:06 PM
Viper's Avatar
Thanks, found this with great photos of pinouts: https://ls1tech.com/forums/conversio...rsion-how.html
Old Jul 5, 2016 | 06:32 AM
shbox's Avatar
I have those on my website.
http://shbox.com/1/harness_connector_faces.htm
Old Jul 5, 2016 | 06:39 AM
Viper's Avatar
I thought I knew your site pretty good; I never noticed the tabs along the bottom!!
Old Jul 6, 2016 | 08:58 PM
Viper's Avatar
Does anyone know how to pop the dash gauge connector out? I have it loose, there is a clip on the left side and it slides into two grooves at the top, but I can't seem to pop it forward. I need to put a pin in B11, an unused slot. In case you are wondering why all the modifications, I'm following this: http://reloaded.fiero.de/index.php/2...owall=&start=2
Attached Thumbnails What wire for speedometer-instrumentclusterconnector.gif
Old Jul 8, 2016 | 06:31 AM
Viper's Avatar
Have to love a dremel tool. Took a tiny bit off the grooves and it was able to pop forward.
