Lt1 bad idle hypertech not communicating
also, use some punctuation in your posts. very tough to read/understand your run on sentences.
The other thing I would suggest is idle air control valve may not be functioning.... so it's causing crappy low idle... 93-95 ECM is dead... upgrade... and things become a hell of lot nicer...
^^ Exactly, why in the heck would you want to go thru all that trouble of changing a wire harness just for a low idle, makes no sense...
It's got a high idle when the car is warmed up or just starting, I've read a lot of forums and tried some things that have been suggested. It slams into gear and shifts hard from 1-2nd. I did a test that I saw was suggested on another forum where you have the car running and then you un plug the IAC and after that you turn the car off plug it back in and start it and it will bring the idle down and it did but it creeps back up if I leave it plugged in.
I have replaced the IAC the TPS the coolant temp sensor I have checked for vacuum leaks with carb cleaner or TB cleaner and fixed the leaks that were needed, I've checked for exhaust leaks with a sniffer, I've checked the throttle blades and they are working properly not catching and the screw is not touching to keep them open, I've cleaned the TB and MAF, I've checked power to the plugs for the TPS and IAC, I've ran the car at night to look for arcing and there's none..... I'm sure there's a couple things I'm forgetting but I'm at a loss, I haven't had the car scanned yet but I need the get this fixed before I do anything else.... I am doing cam and heads after I get this all figured out and having Solomon tune the car for that..... Also the egr isn't sticking or stuck. The car seems to stumble a little but there is no loss of power at WOT or anywhere between
