problems after h/c install
Old Jun 18, 2004 | 10:47 PM
LS1INSIDE's Avatar
Default problems after h/c install
I am done w/ a heads & Cam install including a new opti spark vig 3200 ,306 cam, and an ed wright tuned pcm. but when i went to turn the car the car just cranked and cranked but it never started? i checked for fuel and there was fuel, when i checked for spark and there was none. I replaced the ignition coil tried it again and nothing what can it be? anyone i need to get this car running by tuesday or wed. night at the latest anyone??
Old Jun 19, 2004 | 08:53 AM
TD's z's Avatar
i once done a heads and cam install on a buddys z and forgot to plug in the opti it was one of those dumb as# moments though sounds like that maybe your problem but im sure you already checked that
Old Jun 19, 2004 | 10:27 AM
LS1INSIDE's Avatar
well i went at it again and it was the ignition fuse in the fuse box. it was not making contact because the elec. H20 pump wire was in the way man this thing sounds mean!!!! thanks guys
