Will these plugs work. Br7ef NGK
Old Aug 20, 2016 | 05:06 AM
waltsfastz's Avatar
Default Will these plugs work. Br7ef NGK
Bought these the other day going 2 steps colder they look different from the TR6 I usually run
Old Aug 20, 2016 | 05:07 AM
waltsfastz's Avatar
I got the plugs backwards from the boxes. The longer tip is the tr6
Old Aug 20, 2016 | 06:13 AM
stevo9389's Avatar
from what I recall they are supposed to be a good nitrous plug
Old Aug 20, 2016 | 06:45 AM
waltsfastz's Avatar
i found some good info in the nitrous section on non projected tip plugs. Went ahead and pu them in. Thanks
Old Aug 20, 2016 | 01:25 PM
Nostang's Avatar
Those should work great on the nitrous. They might foul a little on you N/A though.
Old Aug 20, 2016 | 08:56 PM
waltsfastz's Avatar
Ill see what happens. a TRk projected tip has always been good. However I put the 250 shot pills in the other day and wanted to go a step colder
Old Aug 22, 2016 | 07:23 AM
bowtienut's Avatar
The BR7EF non-projected tip is definitely a step in the right direction, as opposed to the TR6, for a sizeable nitrous shot. I think it would be a downright mistake to run a projected tip with a 250 shot.
What's your total crank hp including the 250 shot? I have to assume it's over 700, in which case you might even consider another step colder plug.
I ran BR7EF's with just a 100 shot on mine, and they seemed perfect. My total hp was only ~650. I ran them without nitrous also, although almost no street use, and they didn't foul.
Old Aug 22, 2016 | 09:40 AM
moehorsepower's Avatar
^^ Take his advise.
Old Aug 22, 2016 | 06:51 PM
waltsfastz's Avatar
Never had it on a dyno, Im guessing a modest 475 crank HP. Ill try these a round and go 3 steps next time. Dont really planning on going any more than a 250, But the day may come I do. Thanks for the info
