Funky Oil pressure
Old Aug 23, 2016 | 10:33 AM
thetransamkid's Avatar
Default Funky Oil pressure
So for Starters, I have a 94 lt1 that has about 700 miles on a top end rebuild. Usually the oil pressure would stay constant at about 40 psi at 700rpm idle. Started her up this morning to head to school and oil pressure is hovering at about 60 psi at operating temperature idling at 700 rpms. When I get on the breaks to come to a stop the oil pressure dives down below the 20 psi mark. The car seems to run just fine, it's not sluggish at all nor does it feel like it's losing power. Any help is appreciated.
Old Aug 23, 2016 | 11:06 AM
SS RRR's Avatar
Village Troll
Drain the oil and bang on the bottom of the pan. Oil pump pickup may have fallen off. That, however does not explain the higher-than-normal oil pressure.
Old Aug 23, 2016 | 12:54 PM
Gojira94's Avatar
significant drop while braking (oil moving to front of pan, away from pickup) suggests oil level may be low. But as SSRRR said, that wouldn't account for higher than normal PSI at idle. That would seem to suggest a restriction somewhere. Like a chunk of RTV getting sucked up near the bottom of the oiling system. Hard enough to get it off idle, less available to pick up under braking. (?)
Old Aug 23, 2016 | 09:43 PM
xDetroitMetalx's Avatar
