Question about TB
Old Sep 1, 2016 | 04:01 PM
Black96Z's Avatar
Default Question about TB
Is there any reason not to use a Jegs or Summit brand TB? I currently am in the process of tearing my motor down due to a blown head gasket and will be doing a cam swap sense it is tore down.
Thanks
Old Sep 1, 2016 | 09:01 PM
Cajun ELESS-ONE's Avatar
keep your stock tb. it can handle over 400 hp easy. waste of money. also, if your intake isnt port matched its even more of a waste. and if you re auto, you need to get the ecu tuned for the larger tb or it will idle/shift funny
Old Sep 1, 2016 | 11:12 PM
Black96Z's Avatar
I am aware that a tune is needed. I am aware that the intake will need to be opened up. And if the heads need to be shaved then the intake may also need to be shaved. And port matched. I am thinking about installing the cc306.
