compression help for build
Old Sep 4, 2016 | 01:15 AM
hagff95's Avatar
Default compression help for build
So I had bought an lt4 block a while back and with my lt1 spinning a bearing it's time to finish the build. I bought the block pre-assembled block is bored 40 over
speed pro l2256f (+6.10)
stock length rods
stock crank
stock lt1 heads
Do to budget constraints I've decided with the cc503 I was wanting to run at 11.5:1 or higher static compression
the problem im having is that i my dynamic compression is high is 10+ i know many suggest 9.1:1to be the highest to safely run it on 93 oct
so what should i do lower it mill the heads don't really have money for that buy a super thick head gasket or is it safe to run iti may be entering the wrong numbers not sure
Old Sep 4, 2016 | 07:49 AM
MuhThugga's Avatar
Milling the heads will raise the compression; not lower it.
Can you provide the specs of everything?
Bore
Stroke
Combustion chamber size
Head gasket bore
Head gasket thickness
Piston dome/dish size
Piston deck clearance
Old Sep 4, 2016 | 11:35 AM
hrcslam's Avatar
If you use the Impala head gaskets, I come up with 11.45 SCR, and 9.02 DCR with that cam and rod length.
Those pistons will not work. The part number is for stock bore, you're 0.040 over..... But I used the dish volume for calculatione with the 4.040 bore.
I'm also assuming stock to spec deck height.
Old Sep 4, 2016 | 11:50 AM
hagff95's Avatar
The Pistons are l2256f040 (+6.10cc)
stock heads 54cc
i was using stock deck height and i was using .015 found that number on a website that had the info on it haven't got it measured yet
i don't have a headgasket yet been waiting to figure out what compression to run but it will have a 4.100 or high bore size
Old Sep 4, 2016 | 07:57 PM
KW Baraka's Avatar
Originally Posted by hagff95
......speed pro l2256f (+6.10).....
Originally Posted by hrcslam
.....Those pistons will not work. The part number is for stock bore, you're 0.040 over.......
The Pistons are l2256f040 (+6.10cc).....
Speed Pro part # l2256f040 = 4.040".
KW
Old Sep 5, 2016 | 08:58 PM
hrcslam's Avatar
KW
Yeah those last three digits make a difference.....
Old Sep 6, 2016 | 02:16 AM
KW Baraka's Avatar
Yep....if he'd posted them to begin with .
KW
