Need Help With Mod Choices
Old Sep 15, 2016 | 01:46 AM
CoolRandall's Avatar
Default Need Help With Mod Choices
Hey guys I need a little help to pick out some new mods for my 97 Z28. I got the car almost a year ago it runs great as is but it's completely stock all besides a set of long tube BBK headers, I was wanting to know what kinda mods would help me get started on the path to about 350rwhp. WITHOUT NITROUS or TURBOS. Thanks
Old Sep 15, 2016 | 05:49 AM
rynb15's Avatar
http://elliottsportworks.com/
Old Sep 15, 2016 | 08:28 AM
StealthFormula's Avatar
Many good threads on the topic, I would do some searching around. With that said, I won't get into much detail but to achieve ~350rwhp N/A with an LT1 you are looking at bolt-ons plus a cam. Keep in mind, if your car is an auto you will want a larger torque converter to compliment the cam and if manual perhaps steeper gears.
Old Sep 15, 2016 | 11:27 AM
BALLSS's Avatar
Lloyd Elliott 218/224 cam with mild head porting and a PCM tune would get you 350 RWHP
Old Sep 15, 2016 | 11:51 PM
Ok I got it thanks guys.... ****** how much will that run me?
Old Sep 16, 2016 | 05:12 AM
bufmatmuslepants's Avatar
Old Sep 16, 2016 | 11:52 AM
Christianweber's Avatar
Definitely talk to Lloyd Elliot about heads and cam. Heads, cam, and bolt ons will give you 350+ RWHP. Make sure you check opti, plugs and wires, and other maintenance things. I was about to do heads/cam but ended up getting half the horsepower on the dyno before hand because of bad opti that I didn't even realize was bad. Check everything you can to make sure it is in good shape, then bolt ons, then heads/cam.
