Will the ignition lock cylinder for a manual car fit an automatic car?
Old Oct 11, 2016 | 08:02 AM
ShovelMan's Avatar
Default Will the ignition lock cylinder for a manual car fit an automatic car?
The only difference I'm seeing is that the manual car has a little button on the ignition that you press to turn the key to the OFF position.
Car in question is a 93 Trans Am. Mine is an automatic and I'm seeing only standard transmission lock cylinders in stock. Can't find automatic cylinders in stock.
Old Oct 11, 2016 | 01:54 PM
Spartan7's Avatar
That's the only difference. The steering columns are not transmission specific, so either one will work.
