Urgent LT1/T56 Clutch Help
I'm pretty certain what I'm dealing with is an issue with the master/slave cylinder hydraulics, and I'm looking for confirmation or other theories before I order the parts.
Main symptom is that the clutch isn't fully engaging (I think I'm using that term right, it's always confusing talking about clutches engaging/disengaging and clutch pedal up/down) or to put it another way, the engine is not being fully disconnected from the trans. Also, the pedal feel has changed slightly (I think) and the catch point as you release the pedal has changed significantly, ie since the clutch is basically still caught a little bit when the pedal is against the floor, I only have to let it up a tiny amount for it to be fully caught. This is obviously making standing starts very tricky and shifting gears has also become quite difficult. I can access all the gears right now, but it basically takes double clutching and rev-matching, and even then there's some grinding on gear entry.
The fluid level in the master cylinder is ok, there are no obvious leaks, and I do still have resistance on the clutch pedal, and it does still rebound on it's own, but it's maybe 20% easier to depress than it was before this issue showed up. And it seems to me that when it is in gear and the clutch pedal is all the way out, that it has every bit as much gripping force as it ever did, and is not even hinting at any slippage.
stock or less HP level, stock flywheel, stock T56, SPEC Stage 3 clutch and pressure plate (overkill I know, but it's what came with the trans swap deal)
I have myself convinced that new hydraulics will solve this, as it just feels like I'm not getting enough stroke out of the slave cylinder/clutch fork travel as I should, and if I could just get the clutch fork to pull back a little more and release the friction disk a little more, everything would be fine.
But I'm obviously open to confirmation of my suspicions or alternate theories.
Thanks in advance!
sounds like your hydraulics are failing be it the MC or slave. The more common issue is failing MC
what you are describing is "disengagement" issue
You can buy either a MC or slave or buy both as a "sealed" system which won't require bleeding (difficult) assuming you don't break open the system to install it (should not have to)
If new hydraulics don't happen to fix this issue, is there anything else I should look at?
I took it to a local shop telling them I was certain it was the hydraulics. They called me back and told me that the hydraulics were fine but it needed a new clutch assembly. I was floored because there was absolutely no slippage. I told them to do the job but be sure to provide me with the old clutch assembly.
Sure enough, I got the car back and it was drivable again. Still the old master and slave on it. I took a look at the assembly that they removed and one of the springs had blown out completely.
That was, as far as I know, the stock clutch on my 94z with no modifications at all. About two months after I purchased it. I'm not saying that's what's going on here, but I would say your next step might be to check the assembly. Especially if you and the previous owner of the clutch have/had a penchant for hard launches.
I had actually read of similar accounts that did sound somewhat like what I'm experiencing due to broken/missing/FUBAR'ed springs from the friction disk. I really hope I can get out of this jam without dropping the trans though. just getting it in the one time by myself was almost more than I could handle.
The hydraulics, on LT1, or not hard to replace vs pulling the clutch out. Ideally the new hydraulics will resolve the issue but if not than the tranny will need to come out to look at the clutch
Also since it was a swap with a t56 without a well documented history, I have no idea what noises are normal/abnormal. The puck style clutch and dynomax bullet muffler also don't help matters, but I don't think any new noises accompanied the newly semi-functioning clutch.
Also, if I'm not mistaken, it seems like if am stopped, with the car in gear, and clutch pedal depressed, if I leave my foot down, over time it seems like the clutch starts grabbing more and more, which in my mind further points to the hydraulic pressure bleeding down, due to leaks/air.
Yeah pulling the MC from pedal assembly likely is not fun. I did my A4/T56 swap in a B-body and that pedal assembly is custom using the F-Body hydraulics so pulling my MC is also a PIA under dash-hard to feel bolts also.......but easier/faster than pulling the tranny :-)
Leaning towards some kind of TOB/PP/Clutch plate failure at this point.
I decided to resurrect one of my other cars while I muster up the courage to pull that T56. The other car just needed a new front axle shaft, and at this point I was happy to swap that thing out versus dealing with the T56 again
