Need some help with my build
those springs were intended for the lighter sodium filled LT4 valves. Your valves are heavier and would need more spring with that cam.You should consider another spring choice. The Crane 10308 is a direct drop in spring that would work well with your cam. There are other spring options
Get new valve stem seals also
I would send my heads to Lloyd Elliott for porting. He would also recommend/provide a spring also.
Depending on what head gasket thickness you go with and how much the heads get milled...you likely need a shorter push rod so you will need to measure once heads are back on the car. Generally 7.150 or 7.100 are common but every build is diffrent so measure.
