Effect Of Quench On Detonation Question
I’m building a 396 LT1 stroker motor and I designed this motor to have a .038” quench, (block decked to 9.012” using a .026” compressed head gasket), specifically ….. so that it would run on 93 octane premium unleaded fuel.
The problem is that something got “lost in translation” at the machine shop and they square decked the block to 9.020” instead of the requested 9.012” deck height. Soooooooooo …. after thoroughly washing and painting the block, installing all the freeze plugs, oil galley plugs, cam bearings, main and rod bearings, crank, rods, pistons, rings and torqueing everything to final specs …….. I finally “discovered” this deck height/quench error.
Furthermore, to complicate the problem, I’ve already got the cam, heads, throttle body, etc., etc., etc. to finish this motor, so changing cams to bleed off dynamic compression might be a more expensive solution to this, than just dis-assembling the short block, and sending it back to the machine shop to correct the deck height error.
So here’s the $64,000 question ….. have any of you built an LT1 stroker motor running 12.8 static and 9.2 dynamic compression ratio with a relatively “loose” .046” quench …… and have it run okay during the Summer months on 93 octane fuel ………. WITHOUT pulling timing or having detonation issues???
TIA for any experience, comments and/or suggestions you may have had in building LT1 stroker motors like this.
Here is some info from a thread I posted when I was putting mine together. Just got it running a couple weeks ago and need to update the thread and my sig. https://ls1tech.com/forums/lt1-lt4-m...l#post19272046
Mine ended up being 11.5 SCR and 8.5 DCR with the parts I ended up using and seems to run great so far.
Also where did you get your cam from? If you got it from Lloyd he is pretty good about telling you what will work and what will not.
Nostang, what octane rating fuel do you run when not on the NOS, and just Summer street cruising? Also, have you ever tried running you engine on say 95 octane fuel?
I know the tightest quench is supposed to be best, but maybe your DCR would be getting too high if you had the block decked again.
A call or email to Lloyd would be where I would start.
.......Still, you should be OK with a good dyno + road tune.
And if it'll ease your mind a bit.....get a second PCM and have it loaded with the same primary tune except with a bit of timing pulled.....you know.....for when it gets a bit toasty where you are.
KW
KW
And ..... Thanks! to all who have replied.
You're not running a LT1 intake with your AFR-210 heads, are you?
KW
To throw a caution right back at you however ..... you did use the AFR specific intake manifold gasket with your LT4 intake, 210 head combo right???? Using any GM or OEM replacement LT4 intake gaskets, instead of the AFR gasket ....... will cause you more problems than using the LT1 intake will.
Bought mine in 1999......I guess I have the 'old' version!
KW
My heads are very heavily ported so actually still ended up with the gasket slightly shrouding the ports, which I cleaned up with a dremel, but for most heads the port will be smaller then the gasket. The weird marks in the right side port are marks and shadows on the ceramic coating that only show up in that picture - in person it doesn't look like that (?).
Puck, thanks also for the tip on the Felpro 1206 intake gasket.
At this stage of assembly I'm going to cc the valve reliefs in my flat top pistons, double check all my compression numbers, and then decide what to do.
But again ...... Thanks to all who've replied.
"Engine A"
Bore: 4.030 Stroke: 3.875 Cylinder Head Volume:54.4
Effective Dome Volume: 5.8
Deck Clearance: .020 Quench: .046
Compressed Gasket Thickness: .026 Number of Cylinders: 8
Compression Ratio: 12.61 : 1 Total Displacement (in.3) : 395.42
"Engine B"
Bore: 4.030 Stroke: 3.875 Cylinder Head Volume: 54.4
Deck Clearance: .012 Quench: .038
Compression Ratio: 12.9 : 1 Total Displacement (in.3) : 395.42
So what's the thinking here. What engine will be LESS prone to detonation on 93 octane premium unleaded fuel?
A) 12.61 SCR with a "looser" .046" quench or
B) 12.9 SCR with a "tighter" .038" quench?????
Your comments are always welcome!
Based on what we have, I honestly think that "A" with the looser quench will resist detonating more then B due to the 12.6CR vs 12.9, but with the right cam and good tuning (lots of timing pulled, not ideal) either will work. Keep in mind people run over 11:1 with relatively large .050+ quench, and stock LT1 is ~10.4:1 with a massive .070 quench.
I would say 12.9 is definitely pushing it for pump gas, even with a tight quench. Most recommend staying 12.5 or under, which is what I aimed for.
Don't forget a cam with more overlap and a later IVC can handle more compression safely then a small cam with less overlap and higher cylinder pressure. Solid roller acts smaller then HR so add a few degrees duration to compare the two.
I was told by many folks that anything over 12-1 is pushing it for pump gas. You might get away with it if the tune is spot on but the variability in pump gas could mean some piston damage if you happen to get a bad batch. Secondly, you cannot always hear detonation so you could be damaging the pistons and not even realize it until you have a problem.
If I were going with a pure pump gas 93 N/A engine I would not go over 11.8-1 static just to give a safety window for gas and tuning. You can use a cam with lots of overlap and a late intake valve closing to bleed off compression but that only works at lower rpms. Once you get under load and at WOT the ramming effect of the cam design could cause issues with detonation. Gearing and weight also play a role in detonation. Anything you can do to reduce the load of the engine will help with detonation.
This. What are the cam specs? Opening up the LCA and having a late IVC helps, so do taller gears and a good tune (not just power tuning).
Can you soften the head combustion chambers? That should give you some added volume to offset decking the block more no? Shortening the deck height by .008" should remove 1.7cc. Can't we add ~2cc by softening the heads on the LT1?
There was a guy running like 13.2:1, but used race gas.
