Comp 850 lifter is spongy.
The lifters are brand new. They were cleaned and oiled before install. Is it normal to feel diff spring tension on some lifters ? It almost feels spongy but has enough tension to keep the pushrod from spinning at zero lash. Spring just feels weaker than the rest of the lifters. Will this cure itself once the engine is ran and they pump up with oil?
My $.02 is, using fingers, tighten the poly lock until there is no more "up/down" movement of the PR. That is zero lash. 3/4 turn from there is what I do. I also have 850 lifters.
Like SSR notes, the lifter in ? likely has not as much oil in it. They all pump up with motor running.
However, for many cases, it just doesn't make sense to pull the intake to adjust the rockers. So my method is kind of restrictive. The day I have to adjust them with the intake on, will be more of a challenge for me.
