Narrowing the 383 path.
Old Jan 16, 2017 | 09:45 AM
SS RRR's Avatar
Village Troll
Originally Posted by Pantera EFI
My answer is the 5.7" rod will make more Torque that a 6.0" rod.
I thought I remember a few telling me with the same stroke, a longer rod will allow better leverage which will yield more torque?
Old Jan 16, 2017 | 02:08 PM
pantera_efi's Avatar
Default R/L vs C.R.
Hi, you are correct though you MUST understand the difference between "average" Torque AND "rpm" Torque.
The Short Rod vs Long Rod will change the RPM of the Torque Range.
THIS is way I state a "Torque" value BELOW 5252 RPM AND HP ABOVE 5252 RPM.
This case, you are correct as am I.
The "long" rod keeps the piston higher in the bore at the same crankshaft rotational degree value.
Lance
