LT1 weird vibration
Make a mark from hub to outside edge and drive for awhile....does the mark still line up with inside to outside edge?...if not the outside part of the damper is moving
also since you replaced opti & wires you could have:
a plug wire not all the way on
bad plug wire
bad opti
plug wire arc (especially if using the factory heat shield boots on plug wires)
