Hard starting 93 LT1
Key on, engine off: 42 PSI
Engine running, 38 PSI
Snap throttle test looked good as well, no PSI drop when stepping on it.
Bleed down rate at 10 mintues, no fuel pressure loss. It stayed at 42 PSI.
When I unplug the FPR vacuum line, it simulates WOT. Went up 46 PSI when the line was disconnected.
No codes either.
The car is on LTCC(coil pack conversion) so that eliminates the coil and ICM. Problem existed before this, so LTCC is not the problem.
No fuel present in the fuel pressure regulator
I do datalog. Temp reading for coolant on datalog and on my car always agree. Coolant sensor, wiring and connection is good.
Cycling the key multiple times to prime the fuel pump changes nothing.
93 LT1 Corvette
No codes
On the hard starts, it will idle rough for like a minute. But runs fine.
Next I would point to the coolant sensor, but you already datalogged it and verified it reads correct. The 93 is a simple speed density setup, so that leaves the MAP sensor as the next logical culprit.
Test the MAP with a DMM, voltage should drop from 4.7v on the signal wire down to ~1v as it gets vacuum. If you don't have a vacuum pump, you can suck on the nipple (giggity) and notice a smooth decrease in voltage. Unless you have Superman lungs you won't get anywhere near 1v, but thats not important.
