Having throttle response and starting issues
Old Mar 11, 2017 | 04:06 PM
95lt1fb's Avatar
Default Having throttle response and starting issues
I have a 95 trans am lt1 and was wondering why the car is having starting issues and bad throttle response. The car seems to want to die when you give it gas and doesn't start at times. Replaced optispark, icm, coil, and nothing seems to fix it. Any ideas?
Old Mar 11, 2017 | 08:56 PM
95lt1fb's Avatar
Also, the car starts at times on the 3rd or 4th time, just off and on inconsistent starts with it. Have to give it gas to keep it running and won't properly idle. All ignition stuff has been replaced but plugs and wires. Have a fuel filter for it and the wires and plugs but haven't got around to changing either.
Old Mar 11, 2017 | 09:57 PM
myltwon's Avatar
I would verify fuel pressure
Old Mar 11, 2017 | 10:00 PM
95lt1fb's Avatar
$135 dollars to rent the gauge to check it at parts store. May have to check that out. Seems like a fuel issue but hard to diagnose where it is..
Old Mar 12, 2017 | 05:08 PM
thetransamkid's Avatar
95lt1fb is one of my good friends, looked at the car today and discovered that with the key on it builds 2-3 lbs of fuel pressure. While cranking the car has no fuel pressure what so ever. I'm going to pull the fuel rails and check for leaky injectors. The previous owner also said that the fuel pump had been replaced, a trap door under the rear carpet is evidence of this.
Old Mar 12, 2017 | 06:12 PM
The injectors checked out. Like I said the car will build 2-3 lbs and then it will drop off, won't hold pressure. The previous owner lied about replacing the opti with an MSD unit when in fact it had the 22 year old factory unit still on it. Going to replace the fuel filter for ***** and giggles tomorrow morning.
Old Mar 14, 2017 | 08:55 AM
Gangly's Avatar
Fuel filter first, then check the pressure again. If the fuel pressure is still low, swap out the FPR. Generally a leaky injector or fuel rail wont lose you more than a few PSI and if one is leaking that bad, the smell of gasoline would be extremely strong with a leak of that size.
The general order of things to check/replace with fuel pressure issues when you are strapped for cash and don't have the diagnostic tool available are:
1. Filter
2. Fuel Pressure Regulator
3. Pump
Best of luck!
Old Mar 14, 2017 | 11:11 AM
95lt1fb's Avatar
Replacing the fuel filter today. Already did the FPR yesterday and still nothing.
