Soft Touch rev limiter
Old Apr 16, 2017 | 04:56 AM
Stans 57's Avatar
Default Soft Touch rev limiter
Is it possible to install a soft touch rev limiter on my LT1 engine. The 'die-off' method of action from the computer is problematic. I have a 97 engine set up as a 95 (on a 95 computer from street and performance. They are since out of business since the owner passed away. I would most likely want to turn the stock function off. Is this going to work out or will it be another can of worms? Thanks!
Stan
Old Apr 17, 2017 | 07:15 AM
Shownomercy's Avatar
Man-Crush Warning
Set factory limit to way above what you want, then install a MSD box (or equivalent) and pill it for the correct limit you want. It will pull spark at random when you run into it.
Old Apr 17, 2017 | 07:28 AM
Stans 57's Avatar
ok, MSD would be fine. As the comp is '95 I need to either reprogram or delete the factory limit.
Who can do that for me, without worries? Thanks
