Hv oil pump
Old Apr 23, 2017 | 12:00 PM
CauseyZ28's Avatar
Default Hv oil pump
I'm building a 383 stroker for my 97 camaro, is it necessary to put a hv oil pump or will a standard one will do with a high pressure spring?
Old Apr 23, 2017 | 01:08 PM
BALLSS's Avatar
if your bearing clearances are stock, get a standard volume pump and put the higher pressure spring in it
if your bearing clearances are wider (often done) than that is when a "high volume" pump is applicable
My 383 has wider bearing clearances and I use a HV pump. Been good for 10 years now
Old Apr 23, 2017 | 01:52 PM
CauseyZ28's Avatar
Sweet thank you for the response! Kinda new to building cars but still learning a lot. Just bought a 97 z28 so I'm just seeing what I can do to it for the best results
Old Apr 24, 2017 | 09:49 AM
SS RRR's Avatar
Village Troll
Agreed. If using stock bearing clearance, get a stock s/v pump and use a high pressure spring.
