Gas getting into oil
you have a high pressure Walbro 392 inline. You report 55 PSI as FP....which is high. Check FP with new regulator...if still high you may need a adjustable FPR to knock down the FP to a spec reading
was the 392 in the car before the crank swap?
the external in line type are often added for SC applications.
once you get the adjustable back on, don't plug in the vacuum nipple. plug it with something and check FP. it wants to be 43.5 without vacuum. It will drop a few lbs once you do plug the vacuum nipple back on, normal
Not saying it couldn't be injector leaking, just saying there are other reasons
So with motor running and fuel pressure gauge hooked up and with the vac line pulled, and plugged, you can't get FP down to 43.5 with the adjustable FPR?
