High idle...vacuum leak?
beyond that confirm all vac lines are hooked up correctly and in good shape
I had my TB gasket on wonky and that is where it had a bad vac leak when I put the motor back in. My mistake and didn't find it initially
Now that the heads have been decked the fitment of the intake manifold may be off not allowing a good seal. You would need to see/measure by dry setting the manifold to determine if there is any front/rear china wall gap or runners/head gap. Some decking of the appropriate surface of the intake manifold and/or elongating the holes on the intake may be necessary
smoke test would quickly find this type of leak quickly to rule in/out a intake manifold leak
use FelPro "printle" seal (blue stripe) intake gaskets and Permatex Black "ultra" RTV on the china walls. Let motor sit over night for RTV to cure before starting motor
www.shbox.com
"All of it." is not a valid answer.
Years ago there were many who would run 75 to 150 wet shot on bone stock motors. Larger injectors weren't necessary. Just make sure you know what your O2's are doing when running N2O. Too many would get greedy and blow out a ringland or two because of detonation.
