How much compression safely on pump gas?
Old Jul 25, 2017 | 10:28 PM
flintwrench69's Avatar
Default How much compression safely on pump gas?
Ok a co worker has a 95 Z28 M6 LT1 & wants to build a 383. What's the highest compression ratio that can safely run on 92-93 octane? Also a good set of headers for this setup. I messaged Lloyd & we went over cams, heads & fuel system upgrades. Just wanna hear what you guys think. Were probably gonna go with the milder setup with the better low end since its a street car.
Old Jul 26, 2017 | 01:08 AM
LT1383Z's Avatar
Many claim to have run 12:1 without any problems. I shot for 11:1 because its a pure street car and didn't want to have to worry about gas quality, etc. I run Kooks headers because I wanted to ensure a proper fit though there are more economical options such as xs power, pacesetter, etc.
Did Lloyd recommend a CR with the cars intended usage in mind?
Old Jul 26, 2017 | 03:30 AM
HCI2000SS's Avatar
I run 11:5.1 on 93 pump. My engine builder said he didn't want to go any higher than this on pump gas
Old Jul 26, 2017 | 03:59 AM
98CayenneT/A's Avatar
11.3 : 1 on 93 here
Old Jul 26, 2017 | 06:01 AM
bowtienut's Avatar
I ran 93 octane on the 12:1 heads/cam motor, but only for easy street driving and drag racing (motor never got hot in these circumstances). I ran half race fuel for roadracing where things get really hot. 228/234 HR cam.
The new stroker for road racing will be 11.5:1 and will run pump fuel. 238/246 SR cam.
Old Jul 26, 2017 | 08:53 AM
Yea & does your car have an LT1? I only want info from guys with LT1s!
Old Jul 26, 2017 | 08:55 AM
Catmaigne's Avatar
The highest static comp you can run for 93 octane depends more on your dynamic compression ratio. You could be running over 12:1 safely with the right cam, rod length, stroke, etc. Generally speaking, a larger cam will allow you to run a higher SCR while maintaining a safe DCR. Check out this calculator:
https://www.jeepstrokers.com/forum/calculator/
Old Jul 26, 2017 | 09:02 AM
I never said it was gonna be a strip car, 100% street car. just thought 12-12.5:1 is a bit much on 93. Were going for the less aggressive cam & maybe LE2 heads.
Old Jul 26, 2017 | 09:15 AM
atlantadan's Avatar
Detonation is what kills engines in regards to compression ratios. As Catmaigne said, DCR is more important than SCR, and quench plays a key role here as well. I had a relatively mild cam with a low SCR (Spec'd by Lloyd Elliot), but a higher DCR and a tight quench. Even then, I had a lot of ping on very hot days, and that was with 93 gas - despite Lloyd and Karl telling me I'd "probably" be ok with the DCR/SCR on the engine as-built. Not faulting either of them in the slightest - nobody can tell for sure what an engine is gonna do on the street until its actually on the street.
I opened up the quench a bit and decreased my compression a smidge with a slightly thicker HG and haven't had a ping since.
Old Jul 26, 2017 | 09:18 AM
Nostang's Avatar
Stay with 11.5-1 and under and not worry about anything from 91-93 octane. I am running 12.15-1 and have been told I should not run pump gas on my setup. My dynamic is at 9.3-1 which I was told was too high to run pump gas safely (stay under 8.5-1 DCR for pump gas). I could fatten it up and run a lot less timing and run fine on pump gas but do not drive my car enough to take away power to run pump gas. I can run pump gas putting around town and cruising no problem but would not want to take it up under load in 3rd gear on pump gas. I currently run Sunoco std 110 octane but am planning a change to 260 gt plus soon. If I had it to do over I would have shot for either 11.5-1 or go all the way up to 13.5-1 (either sacrifice some power and not worry about gas or make more power and still run race gas).
Old Jul 26, 2017 | 09:26 AM
64post's Avatar
Would NOT attempt anything close to 12:1 with an LT1 on PGas, fast burn chamber or not.
Old Jul 26, 2017 | 09:53 AM
SS RRR's Avatar
Village Troll
Do you run a knock sensor?
HCI2000SS's Avatar
Guessed I missed the part where you mentioned you wanted LT1 only
Old Jul 26, 2017 | 10:08 AM
Catmaigne's Avatar
Heads are reverse cooled, dudes. 12:1 SCR on 93 with a sizable cam, mildly worked chambers, and proper quench is not that radical 'round these parts.
Old Jul 26, 2017 | 10:10 AM
Catmaigne's Avatar
Who did the tune? There are a few popular tuners out there who use very aggressive timing.
I thought 9:1 was the limit for older SBCs? Guess it depends who you ask. Anyone know the DCR of a stock LT1? Can't find accurate adv duration for a stock cam.
Old Jul 26, 2017 | 10:45 AM
atlantadan's Avatar
I threw away more money on tunes to different tuners than I care to admit. I gave everyone a crack at tuning that car in an effort to get rid of the knock. Started with PCM4L and they essentially ripped me off. Then Solomon and the car was pig rich and he was impossible to work with. Then PCM Performance - tune made good power but still knocked. Then Moe Bailey. Three revisions after datalogging with Moe and he just stopped replying - never did get rid of the knock and my transmission shifted incredibly harsh when warm despite never asking for any changes there. And by "harsh" I mean it would nearly chirp the tires going from neutral-to-drive, or reverse, or park-to-any gear when hot. I know he's got a stellar rep as a tuner, but he left me high-and-dry. (Topic for another thread, perhaps...)
Finally got Chris (Rocko) involved and that guy really took his time and dialed it in using all the tricks in the book. I think we went back and forth with 6-8 logs over the course of 3 months and he had to adjust fueling and timing to such an extent that it became obvious we were just dealing with too much compression.
Popped in the thicker HG and rolled back in the lost timing and haven't had a knock since.
Old Jul 26, 2017 | 11:06 AM
Nostang's Avatar
A very good read...lengthy but has tons of information.
http://garage.grumpysperformance.com...mpression.727/
I was told that reverse cooling is not significant from std sbc cooling as far as compression ratio limits are concerned. I always thought that the reverse cooling and aluminum cylinder heads with efficient chambers helped with running more compression on the lt1's but was informed otherwise. The research I have done and folks I talked to wouldn't chance pump gas on anything over 11.5-1 on a sbc or lt1. I would love to try it out as I know the LSX engines are running 11.8-1 on pump gas but I also know they are running a safer tune with safeties put in the tune for timing retard and fueling if a bad batch of gas is run.
BTW, I am running a 4.060 head gasket and a .033 quench on 12.15-1 flat tops. I built the combo to be on the ragged edge of pump gas but that was in 2007-2008 time when I put the parts together. I was informed that gas has changed a lot since then and not to risk running 93. I do not run a knock sensor due to it being a solid roller cam. YMMV.
Old Jul 26, 2017 | 04:26 PM
LT1383Z's Avatar
My car is 100% street also so I went 11:1 but I would have been comfortable going 11.5:1 but wouldn't go any higher myself.
Old Jul 26, 2017 | 09:02 PM
Same here 11.5 on my LS engine. He doesn't wanna LS swap. He's got a spare engine so we"ll build this & he can drive till its done. Well, I might have to go through his T56, stuck in 4th gear atm. If we build this 383 were staying 11:1 area. This kid is 20 yrs old it"ll be a rocket for him!
Old Jul 26, 2017 | 10:13 PM
KW Baraka's Avatar
Ok a co worker has a 95 Z28 M6 LT1 & wants to build a 383. What's the highest compression ratio that can safely run on 92-93 octane?.......
I run 12.5:1 on pump gas with my 398ci LT4 (1996 Impala SS).
Depends on where you quench is, your cam specs, and the quality of your tune.
Exactly!
KW
