H/C/I ....something unconventional
At this point I'd say you'd be better off just buying a crate engine and paying a shop to install it and call it a day. https://golenengineservice.com/engin...ocks-1992-1997
simple question....if gen1 sbc heads/intakes can be converted ...other than reverse cooling bolt pattern and port shape ie "D" square catherdral whats different in an ls head?
The LT1 is based off the Gen 1 block it's why you can interchange parts with it. The LS engine block isn't designed off a Gen 1 or Gen 2 it's an entirely different block cast with different specifications that's entirely different from it's predecessors. I don't even think the pistons bores of an LT1 could even line up with the valves n the LSX head and the LSX doesn't have reverse flow cooling. It be a like trying to put a round peg in a square hole.
Here's a good read to check out on the different heads chevy made from SBC to LS7 http://www.lsxmag.com/tech-stories/e...ads-to-gen-iv/
Here's a good read to check out on the different heads chevy made from SBC to LS7 http://www.lsxmag.com/tech-stories/e...ads-to-gen-iv/[/QUOTE
i see youve posted another hot link so i went ahead and clicked on this one. after reading through it ...i did find a couple pieces of info helpful. when you start comparing differemt generations of heads in general my idea sounds plausible. most generations were based on the previous and in alot of cases the only difference in some castings vs others could be as simple as what material its made out of steel iron alum. some are the same exact head with various volumes to aid in compression or some are as simple as different size/weight valves. various intake port shapes etc which ive admitted to. its fair you wouldnt want to mix a square with a catherdral or vice versa. the biggest thing that jumps out at me would be the switch from center bolt to perimeter bolt and obviously getting the water jackets to line up and flow properly. but with a competent machinist welding/drilling doesnt seem impossible because gen1 to gen2 has already been done. althought ill admit more crazy than id like to go but yet again just raising the question...
. If they won't be doing that then they will hand you the LS1 heads and tell you to buy an LS1 block to match them too. Fitting LS1 styled heads requires more than a machine shop it would require engineering serious engineering. You'd have to re-engineer the heads, the block, the cooling system, make custom gaskets, custom parts and at the end of the day you'd have spent close to $60,000 just to make a one off wonky hybrid motor that will never make as much power as the real deal.It's just not worth the trouble and I don't think there's a shop in existence that would take on that tasks it really is asking too much. When you see shops doing custom builds like that they do so to showcase their skills to promote their shops at Sema and stuff.
You have to match your heads to your block like mentioned before. 10's isn't that hard to get with a built 383,suspension, and drags. You can pull that with ported stock heads and a stock intake manifold.
It's an LT1 not a TPI motor. You can still hit LSX times with an LT1. The LSX just makes more power N/A which is a huge advantage over the LT1 cube for cube. The time you want to run is very doable but it's a 1/4 that most guys hit with far less work on their motors.
I would recommend to check out some youtube videos of LT1 and LS1 fbodies and check out some guys setups and then figuring out what you want to do from there.
- LS1 and LS6 engines can only use LS1, LS6 and LS2 heads because of the smaller (3.89-inches) bore size. Using heads designed for larger engines will cause the valve-to-block interference.
- LS2 blocks are able to use LS1/LS6 heads because of the larger 4.00-inch bore, as well as the L92-style family of heads that also includes LS3, LS9 and LSA cylinder heads.
- The LS3/L92 engines can use any head except for the LS7 and C5R.
- The LS7 blocks can use any LS-series head but should be matched with heads designed for at least 4.10-inch bores but 4.125-inch bores are preferred.
I couldn't agree more. There is very few people still doing LT1 builds! By starting with the LT1 your already different enough lol. There's only one LT1 car I see at the common car shows around here.
