oil pressure wiring
Old Sep 18, 2017 | 08:59 AM
04Z06vette's Avatar
Default oil pressure wiring
what route does the tan wire for oil pressure sensor go between the sender and the gauge in 07 trans am LT1? gauge is reading 0 which if my searches are correct means the wire is pinched to ground somewhere.
Old Sep 18, 2017 | 09:42 AM
SS RRR's Avatar
Village Troll
Usually if there is no signal the gauge will peg past 60psi. Any weird noises? I'd check with a mechanical gauge to ensure you aren't indeed without oil pressure.
Old Sep 18, 2017 | 09:18 PM
shbox's Avatar
Goes from the sensor into the harness to C220.
http://shbox.com/1/harness.htm
Unplug at sensor and see if gauge pegs. That will tell you if the wire is ok or not.
