Engine hoist chain attachment points
Old Oct 4, 2017 | 12:58 PM
Gulliver's Avatar
Default Engine hoist chain attachment points
I am removing an LT1 from a 1967 Camaro project
Lots of space to remove from the top but not sure best place to attach hoist chains
Thanks
Old Oct 4, 2017 | 01:18 PM
BALLSS's Avatar
There is a eye hook on passenger rear and driver front head unless someone has removed them. You can just use a bolt with washer through chain into those head locations if the factory ones are gone
Old Oct 5, 2017 | 07:29 AM
biketopia's Avatar
Like ****** said, there should be lifting eyes on the engine. If not, just go opposite sides, front to rear on the heads with a chain and 3/8 bolt into the accessory holes and pull it out.
