Water pump
Old Oct 5, 2017 | 09:09 AM
RasheedFenty1's Avatar
Default Water pump
On the LT1 water pump can you just put caps over the heater core outlet and there's another Outlet can you just kept those off
Old Oct 6, 2017 | 12:05 PM
lt1-xjs's Avatar
You can cap off all the 5/8" fittings if you like. However, the steam line to the throttle body needs to be tied into the return (upper) hose to the radiator.
