Trans Cooler Lines hitting oil pan
Just got the motor back in the car and the trans lines are bumbing against the oil pan.. it's a Canton oil pan and I can't remember what it was like before I pulled the motor. Are they always this close to the stock pan and canton pans?
Been many years since I had a A4 but do recall the lines running close to oil pan and there was a hold down clamp near/on front Accessory bracket. Can't remember if they were also secured to block or pan bolt also.
I would think you could massage (bend) them away from any conflict with the Canton
courtesy of Shbox.com. There may be a diagram showing how stock tranny lines are run and mounted
http://shbox.com/
http://shbox.com/
