Back of Cylinder Head LEAK
Old Nov 9, 2017 | 06:54 PM
pdxmotorhead's Avatar
If you chase the threads use a "bottoming tap" to finish, it will make sure the threads are clean clear to the end of the cut, typically you have to use a standard tap first then he bottoming tap to finish.. Good luck..
Old Nov 9, 2017 | 07:10 PM
Shownomercy's Avatar
Man-Crush Warning
It is a wall with threads in it, I don't think you need a bottoming tap for this. Obviously don't run the tap into the other side of the coolant passage.
Make sure you get a 3/8 straight thread tap, they are not standard tapered threads.
Personally, get it swapped to running AN fittings and goop em up
Old Nov 9, 2017 | 07:14 PM
goldrhino37's Avatar
I’m leaning towards AN fittings because the heads are on and the motor is in the car. Would it be okay if I switched to the AN fittings with just less thread?
As so there is less to screw in and would tighten easier
Old Nov 17, 2017 | 09:32 AM
Sorry to bring up an old thread. But I’ve had school and work. I really don’t want to take the heads back off, also I would rather not tap the hole with it bolted to the motor haha. So what if I just cut off a couple threads then deburred and sanded the bolt to mimic the factory ones just shorter.
Old Nov 17, 2017 | 12:06 PM
Man-Crush Warning
Say what?
The bolts you are using now are longer than the OEM factory ones?
Old Nov 17, 2017 | 12:08 PM
No they are factory bolts. But if they were less thread it would screw in tight. In theory haha
