Strange Dyno numbers, Advice requested.
Old Dec 31, 2017 | 08:32 AM
Puck's Avatar
Originally Posted by fuzzyjk
Has a brand new fuel pump in there now that came with the kit. Must be defective.
AFAIK the Vortechs only come with a small in-line pump meant to run in series with the stocker. With more than just a stock build it may not be enough pump even if its working properly. Keep in mind most kits are based around working in a stock motor - with ported heads and a cam, your fuel needs are a lot higher than a stock motor with a Vortech thrown on.
Old Dec 31, 2017 | 08:43 AM
fuzzyjk's Avatar
Thank you for the response. I ordered a new AME 340 intank and will also use the booster that came with the kit.
Old Dec 31, 2017 | 10:19 AM
Shownomercy's Avatar
Man-Crush Warning
The inline stuff is a bandaid to help people justify leaving a factory in tank pump IMO.
Highly recomend you upgrade factory fuel pump wiring
Tank Bulkhead
http://www.racetronix.biz/itemdesc.a...T1-BCA&eq=&Tp=
Pump harness
http://www.racetronix.biz/itemdesc.a...WH-003&eq=&Tp=
You will be asking a lot of OEM wiring.
Old Dec 31, 2017 | 10:26 AM
fuzzyjk's Avatar
Tank Bulkhead
Pump harness
^ very good point. I'll see if they have a plug and play harness.
Another question, I installed a new OEM A/C Delco fuel filter. Could that be causing a restriction and should I upgrade? If so, what would the recommendations be for replacement?
Old Dec 31, 2017 | 10:28 AM
Man-Crush Warning
I run a AC delco OEM filter and lines on mine, no issues with FP losses.
Old Dec 31, 2017 | 10:37 AM
fuzzyjk's Avatar
Great. Thx.
