Building 396 lt1 This so far the build 3.875 crank forged 6.0 h beam forged forged -34 pistons Stock heads so far Anyone know the what compression will be |
can’t know without cc of your combustion chambers, head gasket thickness and deck height. |
Well The deck height very little is being taken. More say just even it up make it even and flat.. the heads should be 54.5 whatever stocks heads. The gasket I want keep this car around 8.8 to 9.0 as it will be running 16 pounds of boost Sto I remember what deck height will be I know it will be hard to say |
According to this calculator with a stock deck height you'd be right around 9:1 with a .040 head gasket: http://www.wallaceracing.com/cr_test2.php |
Would Happen to know what vavle size I should go with for optima power |
Nnnnnnnnnnnope. I've never done a FI engine. Two blokes that have are Blackbirdws6 and ShownoMercy who are sometimes on this forum. |
9.1 still little high maybe cometic has 50 inch gasket I want 8.8 The valves I. Running titiaum intake and stainless exhaust I just need to know what size I should buy to get all power possible |
What your motor putting out |
9.1 isnt high, I run 9.4.1 with LT4 heads and at 12lbs of boost my motor makes 806HP... |
The piston I got are rated at 20 pounds they are diamond blow through pistons i got them gapped at 16 that's the reason why I want it little lower then 9.0 just for peace of mind plus it's going be street /strip car still running intercooled and stage 2 snow system oil cooler. Rated at 650 HP 160 pound injectors I just need to know a good vavle size to go with My t56 will probably blow up. But will worry about that when it does 500+ fuel pump Also what what supercharger crank dampener I called ATI they werent sure if it works with vortec super charger |
Originally Posted by Lsp Przy
(Post 19809302)
(Post 19809299)
Originally Posted by moehorsepower
(Post 19809360)
Yea I'm talking to Loyd on his trick flow heads ported for stroker blower app let him do the cam too I have 1.7 rockers scropion hopefully Loyd can put the heads and bigger vavles where I like it |
(Post 19809030)
..........I want keep this car around 8.8 to 9.0 as it will be running 16 pounds of boost.......... But that's just me. :burn: KW |
I had a budget cast boosted 383 that went 137+mph in the 1/4 at 3850lb with stock (cleaned casting flash) heads with stock sized Manley valves. I was told a good 5 angle valve job was as important as valve size. I'd just let Loyd decide. He is a master. |
© 2024 MH Sub I, LLC dba Internet Brands
