Looking for lifter recommendations for my 395 build.
I'm getting ready to start building my 395 and I wanted to see what some of you guys recommend as far as lifters go. I'll detail the build a little to give you an idea of what I might need.
395 CI 4 bolt with billet mains and arp studs
Scat forged crank
Scat forged H beam rods
Mahle -5cc 4032 pistons
LE TFS heads
LE 242/250 hydraulic roller cam
Torqhead 24x swap with LS1 411 pcm
Performabuilt Level 3 trans with Circle D 5c
And pretty much all other bolt-ons or needed parts.
I'm looking at spinning this combo over 7k so I want a good lifter that can withstand some abuse. Should I start thinking about going tie bar or stick with the dogbone setup? I don't mind spending the money to do this right but if I don't need $700 lifters I'm not going to buy them. I just don't want to cheap out and scatter a new motor because I bought junk lifters that blew up and shot metal all over the place.
Thanks guys.
Which part # did you have in mind? I have a set of Morel 5315's but I wasn't sure if they will handle that kind of RPM with stability.
I run crower link bars in mine on a billet cam, no issues. if you want to push the limits of a controlled 7k HR setup, do not cheap out.
How do y'all feel about link-bar lifters?
