Radiator with no Steam pipe fitting
Can i just connect the steam pipe to the coolant reservoir or do i need to tap into a coolant line. or even drill out the trans cooler fitting and use that as a connection (my car is manual).
http://shbox.com/1/93-94_hoses.jpg
If you have a surge tank plumbed in then you can run your steam pipe to that. But not a reservoir.
The diagram is absolutely correct.
