On my third alternator after EWP install
So... I picked up an upgraded, 100% new, "American Assembled???" (it literally says made in China on the box), 145 amp unit from Hawks Motorsports. http://www.hawksmotorsports.com/alte...45-amp-lt1-v8/
I did not want to risk it with a reman, as they tend to have issues. Anyway, 60 miles later and this brand new alternator died. I am hopeful Hawks will help me out on this one, but ultimately is there something about my accessory setup that is causing this??? or is the addition of an EWP not something that should cause charging issues???
In BOTH scenarios it stopped charging the battery altogether at night, so I had an extra load on the system of my lights. Was I maxing the alternator out for an extended period of time and burning it out or something???
My fans run on High at all times because of my check engine light right now, could that plus lights plus an EWP be the perfect storm to cause repeated failures???
I would think with an upgraded unit like that I wouldn't have issues even with an EWP... Perhaps getting a decent alternator is a crap shoot anyway and this is to be expected. Thoughts welcome, I have a drift event in a week that I will be driving to and from and I do not want this to fail again.
Not saying your alts are not bad but I would fix the "why" the fans run all the time
I have had a EWP for 19 years now on my stock 135 amp alt
IDK what Hawks warranty is....many "chain" auto part stores offer "lifetime" warranty...most if not all are "offshore" made but for returns chain stores have their advantages and alt is typically an easy swap.
You may have other wiring issues causing a constant drain also
I checked all my codes and all I have are EGR, EVAP, AIR, and SKIP SHIFT. I expect all of these as these are all the things I have deleted (and I don't have a tune yet). These are causing the Fans to permanetly stay on high, but they aren't harmful in any way. I will say i accidentally idled it a bit with that electric waterpump unplugged and coolant started boiling out of a hose connection in the heater system!!! Fortunately no harm was done otherwise.
After pulling the old alternator I could hear pieces of the windings shaking around, and a couple pieces of copper wire fell out of the alternator, so yeah it went bad. Definitely not my fault.
Hopefully third time is the charm. Ugh.
Since I cannot afford a tune yet, i am going to install a manual fan switch so I can give the charging system a break, and keep the car running at an optimal temp. With an EWP and Fans blasting on high that thing idles at 180 degrees, and I haven't even installed my double row aluminum radiator yet!
