all gaskets needed for cam swap?
Old Apr 7, 2018 | 03:07 PM
rynb15's Avatar
Default all gaskets needed for cam swap?
Getting a llyod elliott cam, and he has a package with springs rockers, pushrods.
for the timing cover gasket, i ordered this one
https://www.summitracing.com/parts/fel-tcs45956.
or do i need this one?
https://www.summitracing.com/parts/fel-cs9966
i also ordered valve cover gaskets, and intake gaskets. just making sure to get all the right stuff. thanks.
Old Apr 7, 2018 | 04:19 PM
BALLSS's Avatar
the first link + just the pan gasket...may be cheaper than the 2nd link as you won't need some of the gaskets/seals in the 2nd link
get the Fel Pro "printo" seal intake gaskets. (has blue sealer around ports)
I use Permatex Black "ultra" RTV
Old Apr 8, 2018 | 07:54 AM
rynb15's Avatar
i already ordered then top link. i didnt know i needed the oil pan gasket. ill order one now. I also already ordered the intake gaskets. they are fel pro, but not the printo. think ill be ok? thanks for the help.
Old Apr 8, 2018 | 10:27 AM
kingtal0n's Avatar
And Balancer bolt?
Old Apr 8, 2018 | 01:17 PM
BALLSS's Avatar
to remove the timing cover you need to, at least, drop the front of the pan about 1". Pan gaskets are re-useable if they don't tear and you clean all old RTV off of them, and re-apply the RTV on install. Or install a new pan gasket
regular fel Pro intake gaskets are "OK", I just prefer the Printo seal ones
IIRC the hub bolt is a TTY so re-using them is not advises, although some do. They are cheap enough to buy. ARP makes them and theirs are not TTY and are re-useable
Also the WP drive seal is tricky to install without folding over the inner lip so some form of "tool" is strongly advised to use on install. You can buy them on ebay or make one from a Sharpie pen body. Several threads on that
Old Apr 12, 2018 | 05:49 AM
rynb15's Avatar
thanks for all the info, cant wait to get this in!
