SBC Head Conversion
Old May 15, 2018 | 07:14 PM
Shownomercy's Avatar
Man-Crush Warning
Default SBC Head Conversion
Since we all drive cars that make no sense in the time of the great LSX, bare with me.
What is required to convert some AFR 210s to LTX use?
Would it make little to no sense and require a new tune with little to gain? Yes.
Old May 16, 2018 | 09:36 AM
Dirty_Bird's Avatar
Weld up some passages and drill some if i remember correctly
Old May 16, 2018 | 09:56 AM
SS RRR's Avatar
Village Troll
When has anything you've done with that turd made sense?
DOOO IIIIIIIIIIIIIIIIIIT!
Old May 16, 2018 | 07:40 PM
97Z28SS's Avatar
I'm assuming you have a set of standard sbc AFRs because AFR makes Eliminator 210s already to bolt on LT1 engines.
Old May 16, 2018 | 07:42 PM
Man-Crush Warning
Correct
Old May 17, 2018 | 08:51 AM
MuhThugga's Avatar
Makes more sense than modifying stock Vortec heads.
Old May 17, 2018 | 06:25 PM
joelster's Avatar
My friend used to convert them differently. If you weld an aluminum head, you have to get it milled because the heat from the weld will warp the deck slightly. My friend used to drill and tap the oil hole that isn't used and then insert an allen headed plug into it. There's a few other things you have to do, but it' been a long time since I saw one.
Old May 19, 2018 | 04:48 AM
Tbird232ci's Avatar
Going to use a TPI setup?
Old May 19, 2018 | 05:32 AM
ACE1252's Avatar
Wouldn't these make more sense over the AFR SBC head?
http://www.advancedinduction.com/LTX...ccCompHead.php
Edit....nevermind...just saw you already have those SBC heads.
Old May 19, 2018 | 12:01 PM
97Z28SS's Avatar
Take an LT1 head gasket and mark all the locations on the decks where the water passages need to be added/modified and have aluminum plugs made to fit the water passages on the intake surface and have them welded up then surface the heads on both the intake face. but you may have to get your intake manifold spot faced as well.
