Cc305 vs cc503
I have a smaller cam than the 503 in my 383 and have passed Calif. smog for years now
The CC503 has less-ancient XE lobes and gives more area under the lift curve, better average horsepower, than the older Magnum lobes of the CC305.
Edit: just saw the post above mine. Never heard that there are now two different versions of CC305 cams out there .. ??
Comp 305
http://www.compcams.com/Company/CC/c...csid=1102&sb=2
Comp 503
http://www.compcams.com/Company/CC/c...csid=1111&sb=2
Comp XFI 467 (far better choice than either of the other 2)
http://www.compcams.com/Company/CC/c...csid=1107&sb=2
All are similar in valve events in terms of degrees. The 305 is old lobe technology. The 503 is a great cam for stock cubes where emissions may or may not matter, capable tuning helps. These 2 cams are very similar but the 305 has another degree of LSA to assist in staving off cylinder pressure bleed off during filling on the intake stroke. The intake valve closing event and ICL/LSA have primary effects on overlap, which will be your biggest enemy for emissions, as some of the air and fuel charge is leaving the exhaust port unburnt (= high NOX/HC). 3rd choice and others like it- the 467. Longer duration, higher lift, very similar valve events but very different lobes. And another degree of ICL/LSA vs. overlap. More power potential with no worse or slightly better emissions challenges for your tuner. Look at the lift it makes in the almost same number of degrees as either of the other 2. Cylinders will fill a lot quicker and more efficiently and atomize the fuel charge in the intake port a lot better.
Nobody asked what heads you're running on your 383. Care to share? If it's stock LT1 170cc heads then stop me, lol. The other 2 would be about your maximum choices for stock untouched heads.
Comp 305
www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1102&sb=2
Comp 503
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1111&sb=2
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1107&sb=2
cc305 lift w/ 1.6RRs = .544/.544
cc503 lift w/ 1.6RRs = .537/.544
XFI 467 w/ 1.6RRs = .576/.570
I dig the XFI 467 cam mentioned, nice specs on it and it's on more modern, more aggressive XFI lobes. I personally favor the XFI stuff and have been running a custom XFI lobed cam for the past 10-11 years now.
FWIW I run the XFI in my 383. You need a good spring for the ramps of this grind. Lunati is what Lloyd advised for me
I have the XFI in my 383. You need a good spring for the ramps of the XFI. Lloyd advised, and sold me, Lunati springs
EDIT: apologies for double post...hotel internet is slowwwww
Comp 305
Comp 503
