Engine missing
Old Jun 21, 2018 | 12:17 AM
i hot rod's Avatar
Default Engine missing
continuous driving will it causes engine damage or if I drive at a low speed should it be ok
1995 Camaro LT1 158,000 miles $ 8, 000 in repairs just trying to get a bit more life out of it
suggestions?
Old Jun 21, 2018 | 07:26 AM
atlantadan's Avatar
Why is it missing? What are the codes? Could be something as simple as a plug lead arcing. I do recall that running an engine that's missing badly can create more issues, but I am sure others on here will better explain
Old Jun 21, 2018 | 09:05 AM
SS RRR's Avatar
Village Troll
If it's a dead cylinder then you can wash out the cylinder wall with gas as well as contaminate your oil as well as lower power and shittier mpg. You need to find out what the problem is.
Old Jun 21, 2018 | 02:19 PM
i hot rod's Avatar
Thanks for your input
