LT1 head identification.
Old Aug 20, 2018 | 08:30 PM
redlt4's Avatar
Default LT1 head identification.
I'm in the process of removing an LT1 from a 97 Camaro and can't identify the heads? It looks like 22916A? is stamped into the end, not cast in like I would expect. There is also what looks like a 605? also stamped in, but not close to the other ID stamp. The stamping looks like it was done by hand, so some rebuild maybe?
Old Aug 20, 2018 | 09:20 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
If you can, pull a valve cover off.
http://shbox.com/ci/ci161.jpg
https://www.nookandtranny.com/Info_LT1.html
If you're interested, I believe the preferred castings for porting are 10207643 or 10128374.
