Long tube header gaskets
Old Oct 19, 2018 | 10:34 PM
G$pencer's Avatar
Default Long tube header gaskets
97 Z28 Camaro LT1 I just got long tubes for it and it came with steel reinforced gaskets do you think those are strong enough to hold ? The motor is mildly upgraded with a cam cold air intake shift kit I had shorty headers on it and it leaked but the gaskets were not steel reinforced Thanks for your help!
Old Oct 20, 2018 | 01:17 AM
pdxmotorhead's Avatar
I've found the quality of the header flange has the most to do with leaks,
I use single layer copper gaskets on headers and haven't had any issues..
You do need thick flanges to make it work.
I have an old Doug Thorley (Pre Buyout) on my jeep ,,
they seal with a simple 2 layer just fine and the motor is tough on exhaust parts..
Old Oct 20, 2018 | 06:46 AM
atlantadan's Avatar
Remflex header gaskets are a guaranteed seal. Been using them for years and they've never failed to seal.
Old Oct 20, 2018 | 07:35 AM
SS RRR's Avatar
Village Troll
Doesn't have anything to do with if they're strong enough, but rather how true the plane of the header flanges are. If they are not true it doesn't matter what gasket you use it will leak. A paper gasket allows for more margin of error if the flanges aren't completely true, which is a common thing with headers. I've always used Fel-Pro 1402's for my Hooker LT's with great success.
Old Oct 20, 2018 | 08:22 AM
atlantadan's Avatar
True, which is another reason the Remflex graphites are an excellent product. They're about 1/8th of an inch thick - maybe even more - and compress to seal perfectly. The downside is that if you have to remember to re-check the bolts after a bit of driving. Do that once, twice for good measure, and then forget about them
Old Oct 20, 2018 | 09:32 AM
BALLSS's Avatar
^^^^ this. re-tighten header bolts after a few heat cycles
Old Oct 20, 2018 | 10:17 AM
qweedqwag's Avatar
I use GM mls gaskets. work like a champ/
Old Oct 24, 2018 | 08:39 PM
97Z28SS's Avatar
Ultra copper gasket maker on the head and the header never leaks and won't blow out.
Old Oct 26, 2018 | 12:23 PM
Dirty_Bird's Avatar
Percy seal 4 good ftw
Old Oct 26, 2018 | 01:40 PM
Shownomercy's Avatar
Man-Crush Warning
I have percy's stacked aluminum gaskets and they def are better than the paper or single layer stuff. Sealed up my jacked up header flanges just fine.
Old Oct 26, 2018 | 10:37 PM
SS RRR's Avatar
Village Troll
Your flanges are straight.
Old Oct 27, 2018 | 12:03 PM
ACE1252's Avatar
I'm running Percy's as well. No leaks in 8 years. My flanges are warped in the middle(convex to the head), but I think the flange sealing surface itself is true/surfaced flat. I tightened them from the middle out to pull the middle to the head first, then the outer edges.
Old Oct 27, 2018 | 03:31 PM
350 groundpounder's Avatar
Percy's seal for good here. No leaks in 14k miles. No bolts came loose or had to be tightened.
Considering using 1 inch header bolts instead of the 3/4 inch also.
Old Oct 29, 2018 | 11:39 PM
25th TA #748's Avatar
I used Percy's with the Pacesetters on one car, and recently used 1406's to fix a leaking SLP shorty on another. Always had good luck with both when using the 1" long ARP bolts - no backing out, but I do recheck them after a few heat cycles.
Old Oct 30, 2018 | 09:36 AM
SS RRR's Avatar
Village Troll
The other well known secret is using a 3/8's or even 5/16'th header bolt instead of the normal 7/16's. That way access to every primary is far easier and they can be properly torqued down. Also, when using a paper gasket it is extremely important to retorque bolts after a few heat cycles.
