How to Install VATS Bypass Module?
Just like Shbox website
http://shbox.com/1/vats_bypass.jpg
How is yours bypassed at the moment?
This is how I did mine :
The way it's rigged up now is it has a starter solenoid and a relay connecting to the Theft Detterent Relay along with a push button start switch,
Hopefully your method works and I can get my car started
Trying this next week
Also where can I get some resistors from??
You wrote: "Also where can I get some resistors from??"
With Radio Shack gone from the streets and shopping malls, its gotten tougher to find piece parts such as resistors. I like Digi-Key or Mouser for some things but then I still have access to a small, locally owned electronics business here in town. You might call your local fire alarm and home security shops and see if they know of a local electronics vendor.
https://www.digikey.com/
https://www.mouser.com/
Rick
Rick
The way yours is bypass seems complicated, you might need to put all the wires back to stock then do the bypass like said.
Let us know what happens after the bypass.
