LT1 not starting!
Old Jan 6, 2019 | 10:24 AM
92camaroguy's Avatar
Default LT1 not starting!
Working on a project car and having some problems. It will turn over and wont start I have scanned it with no trouble codes.
So I started with the normal (spark and fuel) I'm getting spark but when I check the fuel pressure I get 40 psi when I turn the key on.
Now after the pump primes and it sets a few seconds the pressure will drop around 30psi or so. Is this normal or should I be looking for a leak?
I pulled the fuel rail off and primed it to see if any of the injectors are leaking and let it set for a few hours and they seem fine I'm running out of ideals on this.
Old Jan 7, 2019 | 10:46 AM
SS RRR's Avatar
Village Troll
Lightly spray fuel into the throttle body when starting and see if it catches.
Old Jan 9, 2019 | 06:15 PM
fex77k's Avatar
Use brake cleaner since it will evaporate and wont leave a residue, when I run the methanol out of my motor I just run it at idle till the motor changes pitch and then I know its clear. Dont spray it before the MAF sensor.
Old Sep 14, 2024 | 12:52 PM
guzmanlsx's Avatar
where you able to figure out what was the issue ?
