Twin Turbo Set Up
Old Feb 13, 2019 | 10:16 PM
383lt1z28's Avatar
Default Twin Turbo Set Up
Changing my setup and going twin turbo single plane mono blade tb. I am looking for an inter-cooler recommendations wanting to support 15-20 pounds. Also is there anything I should be aware of or my need to make the conversion go smoother
Old Feb 14, 2019 | 07:29 AM
Shownomercy's Avatar
Man-Crush Warning
Something along these lines
https://www.maperformance.com/produc...iABEgJLmPD_BwE
Although, if you can weld aluminum well, it may be easier to be a bare core and weld on tanks
Old Feb 14, 2019 | 11:20 AM
hokeplaya05's Avatar
i would jump over to the forced induction section and see what the LS guys are doing their for twin turbo intercooler setups in fbodies, shouldn't be too much different
SNM- would that one work in an fbody? seems the outlet would put the charge pipe to the TB over the upper rad support which doesn't seem like it would work without having to cut up the rad support. i would think you'd want the outlet on the right side above the inlet
i would think something like this (i know its for a crowd killer but just using as an example)
https://www.maperformance.com/produc...tang-1994-2004
Old Feb 14, 2019 | 01:22 PM
moehorsepower's Avatar
Twins are not necessary, for one you are pumping in more heat, taking up more space and for only 15-20 lbs a single will do fine
Old Feb 14, 2019 | 07:10 PM
Man-Crush Warning
If hacking up the center rad support scares you, maaaybe one should rethink going twin turbos in a fbody
Agree, but they are so damn cool. Always wanted to do a compound setup to max out complexity and gizmos to tinker with.
Old Feb 15, 2019 | 11:08 AM
I'm not scared to, but my car isn't that clean to begin with so i don't care, if i had a clean example then I'd be more hesitant to is what i was eluding to. I'll probably have to cut up mine to stand up the rad to fit the big single. i was looking at the Huron speed twin turbo kit for ls fbodies and the front mount looks like the one i linked.
twin turbo LTx is cool and different, I'd say go for it for sure.
