Compression question
Saying my car is too high for boost on pump gas ...
Heres what i have
396
Zero decked
6.0 h beam
3.875 crank
-34cc piston
Supervictor intake
80 pound injectors
Camshaft 231 247 581/600 114 lsa plus 1.65 rocker
56cc afr 227
Too my knowledge its 9.25 compression so why wouldn't this beable to run pump gas with boost
Please correct me if im wrong.
You did tune on the computer not to long ago
Send me your addresss so we can fix it before i blow it up
Compression is 9.35 i just got it from lloyd
And tune was set at 9.25 and 77 pound injectors... i have the ford 80 pounders
Now
San Antonio, Tx 78251
Heres what i have
396
Zero decked
6.0 h beam
3.875 crank
-34cc piston
Supervictor intake
80 pound injectors
56cc afr 227
Curious as to what this guys automotive background is that he can make a blind statement like that. Everything looks good, and with a competent tuner I don't see what the problem is. As previously stated don't go to crazy with the boost and have fun. I know someone who had a stock bottom end low mileage LT1 running 7psi of boost and a good tune last something like 12 years. And he only rebuilt it because he got bored and went a different route with his build.
EDIT: I'd like to note that his car was a seasonal car only and he only drove it like 3-4 times a week weather permitting.
Calls him himself mathematical engineer
Says that numbers on my build are 15 static
I confirmed with like with diamond, lloyd , calies everyone told me around 9.2 and 9.35
I thought guy was bullshitting but hes dead serious, says he uses math every day... and has built 4 race spec motor even calculated 3 angle vavle jobs on how it will affect compression.. guy is either a meth head or a ******* genius.. i cant wrap my head around it
https://www.rbracing-rsr.com/comprAdvHD.htm
But i dont know the ab what ever that was so i cant be accurate
.i just put 50 as the number and my dynamic sits a 7.0
