1996 impala crank, no start
Old Apr 16, 2019 | 09:56 AM
Sweeney96's Avatar
Default 1996 impala crank, no start
Just bought It. Ran fine for 3 weeks. Stalled 2x way home from work but started back up. Second time took a little longer to fire. Changed crank position sensor, didn’t start. Put old one back in, didn’t start. Went back 15 min later, started. Also has fuel pressure. Anyone have any suggestions?
Old Apr 16, 2019 | 11:14 AM
StealthFormula's Avatar
Did you replace the crank sensor with an OEM ACDelco one or aftermarket? If aftermarket, maybe try a new OEM one. When I had no start issues it was my ICM that was going/went bad but I'm not sure if that's the issue you have here because if I recall correctly mine didn't even crank.
