LT1 Transplant problems
Old Apr 22, 2019 | 06:59 AM
rrwebster's Avatar
Default LT1 Transplant problems
Putting a LT1 into my 1990 Chevrolet Silverado C3500. Prior to this install I've done the same on my 86 Camaro and on my 77 Corvette. Major difference is the wiring harness, this one appear to have come from a 94 Caprice.
Symptoms: no flicker on test light during crank when stuck in Injector (Sometimes). will start and run for a little bit half the time.
Old Apr 22, 2019 | 07:44 AM
myltwon's Avatar
sounds like a VATS issue
Old Apr 22, 2019 | 08:43 AM
rrwebster's Avatar
I have it disabled in the build. I drove this vehicle around my driveways. stopped, turn it off. then this started... it's not constant, I've started it up and moved it twice since.
if I put my test light (grounded) into the ground side of one of the injectors it will start right up and run. when I remove it, the idle increases, it will run for around 20 seconds and then die... so I understand your thought about VATS. but if I leave the test light in the ground side of an injector, it will sit and idle (poorly) for as long as I leave it there.
Old Apr 22, 2019 | 08:41 PM
NewEnglandFormula's Avatar
shbox.com has a lot of good info on wiring issues and all the wiring diagrams. make sure there is a ground from battery to motor to frame to body back to battery.
Old Apr 27, 2019 | 07:44 PM
rrwebster's Avatar
Default Bad harness
I bought a new harness and all is well The old one had a lot of cutouts this is a 94 Caprice harness which runs the engine just great but the transmission won't shift and I'm going to post a new post for that
