Lt1 engine
Old May 6, 2019 | 08:19 AM
Formula19962001's Avatar
Default Lt1 engine
Hi im new to lt1 i have a 1996 firebird formula i just did the opti spark but i remove the timing chain cover and hub does this needs to be time or the hub needs to be install in the same way it was remove cause my car dosent wNt to start
Old May 6, 2019 | 09:15 AM
SS RRR's Avatar
Village Troll
Hub does not need to be pressed on a specific way. There is no heavy side to the damper/not a balancer. A stock LT1 engine is internally balanced in the front and externally in the back via flexplate/flywheel.
