Fuel pressure issues
Old Aug 21, 2019 | 03:04 PM
Jason28's Avatar
Exclamation Fuel pressure issues
94 z28 Camaro
I get 38 psi at idle. If I snap the throttle is get like 48.if. Run it up to 3g I get 38 psi.is that correct? I got a new pump and then the car started running like crap.just changed the filter. Then I’m in 4th gear and go up a hill I feel the motor jumping and missing.i used to be able to spin the tires I’m 2nd.want even do it in first now unless I pop the clutch.no ses and I have a recent data log if needed.car has a built 355 the injectors are stock.it was fine before new pump. When I first ran it on the new pump it was perfect.30m later it started bouncing. And to add everything on the motor is new.
