Lt1 NA 383 build. Opinions welcome
Old Dec 3, 2019 | 12:33 PM
  #81
PARMY's Avatar
Any updates?
Old Dec 3, 2019 | 02:07 PM
  #82
Adam1203's Avatar
Originally Posted by PARMY
Any updates?
I have been driving it. I am still learning the ls1 computer the car makes good power however when I am cruising between 35 and 45 the car starts jerking if I put any load on the engine the miss goes away.
Old Dec 3, 2019 | 03:30 PM
  #83
Fast355's Avatar
Usually jerking is a sign of either being lean or having too much timing.
Old Dec 4, 2019 | 07:29 AM
  #84
Adam1203's Avatar
When I am idling bank 1 jumps to 25 which is maked out and bank two stays around -1 to -1.2 on ltft. I have read the 411 pcm likes to be as close 0 as possible and anything plus or minus 2 is acceptable. When I get on the highway they both balance out nicely and are only off about .5 at most but at idle and low rpms they are way off. I plan on changing both 02 sensors and the maf and seeing what happens.
Old Dec 6, 2019 | 06:05 PM
  #85
Adam1203's Avatar
I replaced both o2s and the maf. It runs a lot better actually idles much better but the miss is there still. That said the miss is less noticeable. Is it possible that it's an issue with the tune? I have tried reaching out to moe via pm and phone and have not recieved a reply. Not sure if he is on vacation or something.
